Direct Level Set Surface Rendering
OctaneRender® can render level set surfaces, including those from VDBs, without first converting them to meshes. Below (figure 1) is a rendering of the famed XYZRGB Dragon based on the level set surfaces made available by the original scanned range sets.
XYZRGB Dragon
Figure 1: Level set surface rendering of the XYZRGB Dragon
Stanford Bunny
Figure 2: Level set surface rendering of the VDB level sets of the Stanford Bunny
The level sets also work with Vectron, which allows you to add Procedural effects over surfaces defined by VDB level sets.
OSL Texture
Figure 3: A modified OSL texture that adds Procedural effects to level set surfaces
Procedural Displacement
Figure 4: An example of a Procedural displacement added on surfaces defined by VDB level sets
