Issue 5. Render Looks Strange
Problem: |
Concentric circles over the image or unusual effects including Bump map not working. |
Solution: |
Check the imported scene's scale and change the Ray Epsilon value. This is due to the scale being incorrect by a factor of 100 or 1000. OctaneRender® expects one unit in the scene to equal one meter. Adjust export settings in the modeling application, or adjust the import settings in OctaneRender. |
Problem: |
Facetting occurs, revealing the underlying polygonal mesh, geometry, or normals issues. |
Solution: |
Ensure that the geometry and normals are correct in the modeling program. Re-export the scene if necessary. Make sure the Normal Smoothing boolean value (smooth) is enabled for each material in the Node Inspector. |
Problem: |
Bump map does not show up. |
Solution: |
When a Bump map and Normal map are loaded, the Normal map takes priority and the Bump map will not be used. |
Problem: |
Images do not look right on the model. |
Solution: |
This may be due to the way the model was UV unwrapped. This may need to be redone more precisely in the 3D modeling application and exported again. |
