Problem:
Incorrect driver installed
Solution:
Read the release notes to ensure that you have the correct driver version installed. Remove the old driver versions and then install the proper version. You may need to use a tool such as Driver Sweeper to uninstall all driver components.
Problem:
Video card is not CUDA®-enabled
Solution:
Check the list below to ensure that your card is CUDA-enabled:
http://developer.nvidia.com/cuda-gpus
